Lists the MLD group membership for the specified VLAN or group.
| name | Specifies a VLAN name. |
| v6grpipaddress | Specifies a group IPv6 address. |
| MLDv2 | DisplayS the MLD group in MLDv2 format (if group record is MLDv2 compatible, otherwise displayS in earlier format). This option is not supported in this release. |
MLDv1.
If no VLAN is specified, all VLANs are displayed. You can also filter the display by group address or by multicast stream sender address.
The following command lists the MLD group membership for the VLAN accounting:
show mld group vtest3
Output from this command looks similar to the following:
Group Address Ver Vlan Port Age ff03::1:1 1 vtest3 4:5 25 ff03::1:2 1 vtest3 4:5 25 ff02::1:ff22:124 1 vtest3 4:45 26 ff05::a:abcd 1 vtest3 4:15 23 ff05::a:abce 1 vtest3 4:15 23 ff02::1:ff22:112 1 vtest3 4:45 26 ff02::1:ff1f:a418 1 vtest3 4:45 26
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
